[OpenLayers-Dev] Protocol.HTTP callback
Andreas Hocevar
ahocevar at opengeo.org
Thu Dec 13 01:19:55 PST 2012
That's right. Otherwise it would be marked "APIProperty", not "Property".
Andreas.
On Thu, Dec 13, 2012 at 10:18 AM, Denis Rykov <rykovd at gmail.com> wrote:
> Yes, events mechanism works flawlessly.
> So it looks like OpenLayers.Protocol.HTTP.callback option generally is only
> for internal use?
> On Thu, Dec 13, 2012 at 4:14 PM, Andreas Hocevar <ahocevar at opengeo.org>
> wrote:
>> You can listen to the vector layer's loadend event. Will that work for
>> you?
>> Andreas.
>> On Thu, Dec 13, 2012 at 9:18 AM, Denis Rykov <rykovd at gmail.com> wrote:
>> > Is it possible to use callback option of OpenLayers.Protocol.HTTP for
>> > custom
>> > user's callbacks?
>> > I've tried to debug one app and have discovered that callback option is
>> > overriden by OpenLayers.Strategy.BBOX.merge function in my case.
>> > Denis
>> > On Thu, Dec 13, 2012 at 3:14 PM, Andreas Hocevar <ahocevar at opengeo.org>
>> > wrote:
>> >> It means it should only be set through the constructor options, and
>> >> not be changed at a later time.
>> >> Andreas.
>> >> On Thu, Dec 13, 2012 at 4:39 AM, Denis Rykov <rykovd at gmail.com> wrote:
>> >> > What does mean `read only` in this context:
>> >> > https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Protocol/HTTP.js#L52
>> >> > _______________________________________________
>> >> > Dev mailing list
>> >> > Dev at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> >> Andreas Hocevar
>> >> OpenGeo - http://opengeo.org/
>> >> Expert service straight from the developers.
>> > Dev mailing list
>> Andreas Hocevar
Andreas Hocevar
More information about the Dev
