[OpenLayers-Dev] Towards slick panning and animated zooming
Andreas Hocevar
ahocevar at opengeo.org
Fri Dec 21 07:32:26 PST 2012
For those of you who want to test, the live example site also provides
all examples that OpenLayers ships with, and you can test
http://ahocevar.github.com/openlayers/mobile-wmts-vienna/lib/OpenLayers.js
with your own applications. Note that the TileManager is not enabled
by default. To add it, configure your map with the following option:
tileManager: new OpenLayers.TileManager()
The whole source code is available at
http://github.com/ahocevar/openlayers/tree/mobile-wmts-vienna.
Andreas.
On Fri, Dec 21, 2012 at 12:46 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> I added another pull request that is used in my mobile-wmts-vienna
> branch and in the live exymple now:
> https://github.com/openlayers/openlayers/pull/810
> Use transitionend listeners where available. Should be easy to review.
> Andreas.
> On Wed, Dec 19, 2012 at 9:41 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Hey fellow developers,
>> I don't know if you saw the enthusiastic tweets (e.g.
>> https://twitter.com/19_norte/status/281134258725199875), but
>> http://ahocevar.github.com/openlayers/mobile-wmts-vienna/examples/mobile-wmts-vienna.html
>> shows the improvements in tile rendering we can get with four pull
>> requests. All these pull requests have been thoroughly tested, and are
>> the result of client work at OpenGeo. To bring these improvements into
>> master, I am asking for reviews:
>> http://github.com/openlayers/openlayers/pull/702
>> New tile image cache and tile queue improvements. This pull request
>> gets rid of the current tile queue, which I know many people were
>> unhappy with. It adds a new TileManager class, which delays tile
>> loading for panning (replacement for previous tileLoadingDelay in
>> Layer.Grid) and zooming to avoid unnecessary tile image requests. It
>> also keeps references to image elements, so they can be reused when
>> the user pans or zooms back to regions or zoom levels that were
>> already visited.
>> http://github.com/openlayers/openlayers/pull/800
>> Use translate3d to enable GPU support where available. This introduces
>> an applyTransform method on the map, which will use an appropriate
>> positioning method for the layerContainerDiv. Without any transform3d
>> styles on the layerContainerDiv, style.left and style.top will be used
>> just like we currently do, and scale transforms will be used for
>> scaling. But with a translate3d style on the layerContainerDiv, all
>> positioning is made with translate3d, and scaling is done with
>> scale3d. By doing so, the GPU kicks in and brings greatly improved
>> dragging and pinch-zooming performance.
>> http://github.com/openlayers/openlayers/pull/503
>> Animated zooming. This depends on #800, and I will rebase it when #800
>> is in. For now, it is best to look at the three commits mentioned in
>> https://github.com/openlayers/openlayers/pull/503#issuecomment-11495176.
>> This change includes some improvements to the MouseWheel handler, and
>> better mousewheel defaults for the Navigation control, to allow for
>> usable and predictable wheel zooming on touch pads.
>> http://github.com/openlayers/openlayers/pull/803
>> Tween: skip frames when minimum frame rate is not reached. We use
>> requestAnimationFrame for tween already, but we have no control over
>> the frame rate. This change introduces a new minFrameRate option. When
>> set, frames will be skipped if the animation gets too slow. The effect
>> of this can best be seen when zooming with #503 applied in Firefox:
>> instead of the 20 frames (which work fine in Chrome), about half of
>> the frames will be skipped because Firefox can not scale the
>> layerContainer fast enough. The visual effect of animated zooming
>> still works fine, and users do not have to wait too long for the zoom
>> to finish.
>> Thanks for any reviews! With these changes in, the visual appearance
>> and performance of OpenLayers will be on par with Leaflet.
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> Andreas Hocevar
Andreas Hocevar
More information about the Dev
