[OpenLayers-Dev] Generate multiple polygons on a single click
Fernando López Llanos
flopezlla at hotmail.com
Mon Jun 11 23:00:06 PDT 2012
Hi I'm a newbie in openlayers, I took the following code from the examples provided by openlayers, I'm trying to create 4 polygons with a single click, is this possible?
Thanks in advance for any help.
Code:
<!DOCTYPE html><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0"> <meta name="apple-mobile-web-app-capable" content="yes"> <title>Test</title> <link rel="stylesheet" href="style.css" type="text/css"> <style type="text/css"> html, body { height: 100%; } #map { width: 100%; height: 80%; border: 1px solid black; } </style> <script src="../lib/Firebug/firebug.js"></script> <script src="../lib/OpenLayers.js"></script> <script type="text/javascript"> var map, vectors, controls; function init(){ map = new OpenLayers.Map('map'); var options = {numZoomLevels: 3}; var graphic = new OpenLayers.Layer.Image( 'some title', 'image.png', new OpenLayers.Bounds(-180, -88.759, 180, 88.759), new OpenLayers.Size(800, 200), options ); graphic.events.on({ loadstart: function() { OpenLayers.Console.log("loadstart"); }, loadend: function() { OpenLayers.Console.log("loadend"); } }); var jpl_wms = new OpenLayers.Layer.WMS( "title", "http://t1.hypercube.telascience.org/cgi-bin/landsat7", {layers: "landsat7"}, options); vectors = new OpenLayers.Layer.Vector("Vector Layer"); map.addLayers([graphic, vectors]); map.addControl(new OpenLayers.Control.LayerSwitcher()); map.addControl(new OpenLayers.Control.MousePosition()); controls = { point: new OpenLayers.Control.DrawFeature(vectors, OpenLayers.Handler.Point), shape:
//*************This is what i'm trying to do*************************************************** for (i=0; i<5; i++) { new OpenLayers.Control.DrawFeature(vectors, OpenLayers.Handler.RegularPolygon, {handlerOptions: {radius: 5, sides: 4, snapAngle: 45 }}), }
drag: new OpenLayers.Control.DragFeature(vectors) }; for(var key in controls) { map.addControl(controls[key]); } map.setCenter(new OpenLayers.LonLat(0, 0), 3); document.getElementById('noneToggle').checked = true; } function toggleControl(element) { for(key in controls) { var control = controls[key]; if(element.value == key && element.checked) { control.activate(); } else { control.deactivate(); } } } </script> </head> <body onload="init()"> <h1 id="title">Map</h1> <div id="tags"> image, imagelayer </div> <div id="map" class="smallmap"></div> <div id="controls"> <ul id="controlToggle"> <li> <input type="radio" name="type" value="none" id="noneToggle" onclick="toggleControl(this);" checked="checked" /> <label for="noneToggle">Move</label> </li> <li> <input type="radio" name="type" value="point" id="pointToggle" onclick="toggleControl(this);"/> <label for="pointToggle">Point</img></label> </li> <li> <input type="radio" name="type" value="shape" id="lineToggle" onclick="toggleControl(this);"/> <label for="lineToggle">Shape</label> </li> </li> </ul> </div> </body></html>
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120611/b1770059/attachment.html>
More information about the Dev
