[OpenLayers-Dev] Order coordinates in GeoJSON
Steven M. Ottens steven at minst.net
Fri Mar 2 08:58:51 EST 2012
Hi all,
The coordinate-order has always been a source of confusion and IIRC
nowadays the recommended order is 'Latitude, Longitude'. However
OpenLayers by default expects 'Longitude, Latitude'. The GML format
recognises this and provides a 'xy' parameter to swap the order if
necessary.
The GeoJSON format, however, does not. I ran into this problem because
I'm using a WFS and WPS which according to the specs should return
'Latitude, Longitude'. Since GeoJSON is so much easier to use than GML,
I was wondering if adding the xy parameter to the GeoJSON format is desired.
Regards,
Steven
More information about the Dev mailing list
