[OpenLayers-Dev] Firefox and canvas, strange behavior
Andreas Hocevar ahocevar at opengeo.org
Tue Mar 6 14:05:50 EST 2012
I found a solution: in Firefox, it is not enough to set
img.crossOrigin = null;
What you need to do is
img.removeAttribute("crossorigin");
Also note a typo in Tile/Image.js:
                if (url.substr(0, 5 !== 'data:')) {
should read
                if (url.substr(0, 5) !== 'data:') {
Andreas.
On Fri, Feb 17, 2012 at 10:26 AM, Frederic Junod
<frederic.junod at camptocamp.com> wrote:
> Hello all,
> I'm trying to create a demo to shows the new canvas capabilities in
> OpenLayers [1].
> The attached example loads a basic OSM layer and turns the tiles into
> grayscale. This works great with Chrome 16 and 18; even IE9 displays
> the layer correctly [2].
> But I can't make it work with FireFox 10: the tiles are still in color
> (and in the wrong position). Using firebug, I see that the img src are
> correct (data url in base64).
> Repaint bug? src size limitation?
> Any advice welcome
> fredj
> [1] https://github.com/openlayers/openlayers/commit/ad201f3a80827f8189d9d798fb8c93fe67fd8865
> [2] With IE9, a local proxy must be created, this comments inside the
> attached file.
> Frédéric Junod
> Camptocamp SA
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
