[OpenLayers-Dev] Exception in OpenLayers.Layer.Grid.removeBackBuffer
Eric Lemoine eric.lemoine at camptocamp.com
Tue Mar 13 18:11:04 EDT 2012
On Tuesday, March 13, 2012, Tim-Hinnerk Heuer <th.heuer at gmail.com> wrote:
> Hi List,
> Intro: I'm Tim-Hinnerk Heuer, a web developer at Landcare Research New
Zealand. I've been to the last FOSS4G in Denver and I'm a committer on
MapFish Print, but mainly a JavaScript-Front-End-Developer. I've learned a
lot about JavaScript in the past years and even developed an OpenLayers
extension to OpenLayers.Layer.WMS called OpenLayers.Layer.VideoWMS. You can
find that at my GitHub @ http://github.com/geekdenz/openlayers . Haven't
made a pull request yet, because it might not be stable yet...
> The real reason for my post is (hope this is the right place to post
this):
> I've come across an error/exception in OpenLayers, that seems to be
pretty new (using the latest git master version):
> In Chrome:
> Uncaught Error: NOT_FOUND_ERR: DOM Exception 8
> In Firefox:
> Node was not found
> Around line 26075 (in my own built version).
> I guess line 702 in Layer/Grid.js in the latest build
> Code around it:
>      * Method: removeBackBuffer
>      * Remove back buffer from DOM.
>     removeBackBuffer: function() {
>         if(this.backBuffer) {
>             this.div.removeChild(this.backBuffer); // THIS IS THE LINE
>             this.backBuffer = null;
>             this.backBufferResolution = null;
>             if(this.backBufferTimerId !== null) {
>                 window.clearTimeout(this.backBufferTimerId);
>                 this.backBufferTimerId = null;
> Part of the stack trace is:
> OpenLayers.Layer.Grid.OpenLayers.Class.removeBackBuffer
> OpenLayers.Layer.Grid.OpenLayers.Class.applyBackBuffer
> OpenLayers.Layer.Grid.OpenLayers.Class.moveTo
> OpenLayers.Map.OpenLayers.Class.moveTo
> OpenLayers.Map.OpenLayers.Class.setCenter
> OpenLayers.Control.OpenLayers.Class.wheelChange
> It happens when I zoom about in our map or when I open the Print Window,
which has another map in it. It's only really a problem in the print
window, because the whole map breaks. In the normal map it is not a problem
so much, because you only occasionally see that error in the developer
tools or Firebug.
> This problem only got introduced recently but I don't know through which
change. I suspect it has something to do with how I initialize the print
window. It's using GeoExt's SimplePrint class and quite a bit of custom
code. (On a side note the print window has been in the app for ages.)
> It is also only happening when I quickly zoom about and then open the
print map, not when I wait for everything to load.
> I suspect it has something to do with the fact that the print window has
an extra vector layer with a rectangle of where the to be printed map is
and that it gets set as the base layer. However, I tried explicitly
removing it and adding it later and also tried to do a
map.setBaseLayer(myBaseLayer) to no avail. In fact that line throws the
same error.
> Please help if you can, this bug has been annoying me for quite some time
now already.
> Thanks,
> Tim
> Twitter: @timhheuer
> Blog: http://www.thheuer.com
Hi Tim
This may be a bug in the new backbuffer code. To debug this we'd need a
simple example (w/ no print window) that exhibits the bug. Have you tried
reproducing the issue with one of the OpenLayers example?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120313/ca95dcc0/attachment.html
More information about the Dev mailing list
