[OpenLayers-Dev] Exception in
OpenLayers.Layer.Grid.removeBackBuffer
Tim-Hinnerk Heuer
th.heuer at gmail.com
Wed Mar 14 03:22:23 EDT 2012
Hi Andreas,
Ah that sounds genius!
I'm cloning the layers, probably while the layers are not completely
loaded. So, I'm guessing an OpenLayers bug following your logic. Hey, we
might get to the bottom of this yet. Will have another look at OL tomorrow,
but it seems you are spot on, Andreas. Can you let me know if you have time
to look at it. You seem to know that part of OL better.
Cheers,
Tim
On Wed, Mar 14, 2012 at 8:08 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> The only occasions I could think of that could potentially make
> this.backBuffer both non-null and not a child of this.div is when a
> layer is cloned during tile loading, or when the layer is added to a
> second map without cloning it. The latter would be an application bug,
> the former an OpenLayers one.
> Andreas.
> On Wed, Mar 14, 2012 at 6:16 AM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
> > On Wednesday, March 14, 2012, Tim-Hinnerk Heuer <th.heuer at gmail.com>
> wrote:
> >> Hi Eric,
> >> I couldn't reproduce the problem in any simple example. However, I did
> fix
> >> it within OpenLayers. Basically, I changed a couple of lines:
> >> * Method: removeBackBuffer
> >> * Remove back buffer from DOM.
> >> removeBackBuffer: function() {
> >> if(this.backBuffer) {
> >> if (this.div.hasChildNodes(this.backBuffer)) { // ADDED THIS
> >> LINE
> >> this.div.removeChild(this.backBuffer);
> >> } // AND OF COURSE THIS
> >> this.backBuffer = null;
> >> this.backBufferResolution = null;
> >> if(this.backBufferTimerId !== null) {
> >> window.clearTimeout(this.backBufferTimerId);
> >> this.backBufferTimerId = null;
> >> It's in my public repo. Should I make a pull request? I know it's yet
> >> another check and might slow down things, but stability seems more
> >> important. What do you think?
> > I'm sure this fixes it. The thing is I really don't understand how
> > this.backBuffer can be both non-null and not a child of this.div. I think
> > this should never occur. It may occur there's some code that empties the
> > layer div without calling removeBackBuffer beforehands, but the lib does
> not
> > have such code as far as I know.
> > Eric Lemoine
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel : 00 33 4 79 44 44 96
> > Mail : eric.lemoine at camptocamp.com
> > http://www.camptocamp.com
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120314/5a6f4007/attachment.html
More information about the Dev
