[OpenLayers-Dev] Exception in OpenLayers.Layer.Grid.removeBackBuffer
Andreas Hocevar ahocevar at opengeo.org
Wed Mar 14 04:07:57 EDT 2012
Eric, you're right. I just looked at the clone method, and indeed
there is no way that a cloned layer could get any backbuffer related
properties from the original.
So Tim, I guess we still need a minimal example that exposes the issue
to investigate it further.
Andreas.
On Wed, Mar 14, 2012 at 8:28 AM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Wed, Mar 14, 2012 at 8:08 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> The only occasions I could think of that could potentially make
>> this.backBuffer both non-null and not a child of this.div is when a
>> layer is cloned during tile loading
> I had thought about this too. But I'm still failing to understand how
> cloning can lead to this state. Do you mind elaborating a bit? Thank
> you.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
