[OpenLayers-Dev] Submitting code for OpenLayers - git
Alexandre Dube
adube at mapgears.com
Fri Mar 16 08:20:26 EDT 2012
Thanks Eric for your reply.
Alexandre
On 12-03-16 01:51 AM, Eric Lemoine wrote:
> On Thursday, March 15, 2012, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> > Hi,
> Hi Alexandre
> > I would like to contribute a patch that was mentioned in a ticket
> in the original TRAC. What are the actions I need to do until I end
> doing a "pull request" ?
> Quickly put:
> - fork openlayers on github
> - clone your openlayers repo locally
> - create branch
> - check out branch
> - apply patch to branch
> - push branch to your github repo
> - issue pull request
> > Should I create a new issue in github ? Is there some kind of
> "Submitting code" documentation to OpenLayers for the git repository ?
> > The current wiki still refers to TRAC [1].
> Yes, we need to change that.
> > Can we still use it and contribute svn patches ?
> Pull requests work best for the OpenLayers developers.
> After 2.12 I hope we can discuss again what to do with Trac. I
> personally don't want to work with two issue trackers anymore.
> Cheers
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com <mailto:eric.lemoine at camptocamp.com>
> http://www.camptocamp.com
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120316/0b01722e/attachment.html
More information about the Dev
