[OpenLayers-Dev] Alternative to Proj4JS
Michael Adair
madair at dmsolutions.ca
Tue Mar 27 09:40:53 EDT 2012
Peter,
Or we can also change the Proj4js license. IANAL and I don't pretend to
understand subtleties of licenses but if LGPL is a blocker, I'm all in
favour of changing that so that the Proj4js gets used as widely as
possible. I'll raise the issue on the MetaCRS list.
Mike
On 27/03/2012 7:00 AM, Day, Peter A (EXP) wrote:
> I have been part of a team developing a system for a customer which
> uses Openlayers as its map interface. We use Proj4JS to perform the
> coordinate conversions.
> Because both Openlayers and Proj4JS are Open Source we have to get
> these approved for use. Openlayers is no problem but unfortunately the
> corporate lawyers have jumped on Proj4JS as it uses the L-GPL license.
> I don't pretend to understand the reasons behind this but it means
> that we cannot use it.
> Does anyone know of an alternative Javascript library -- either OS or
> commercial -- that we could use to replace Proj4JS?
> (What is most annoying is that Proj4 and the Java conversion use MIT
> licences which would have been acceptable)
> Thanks
> UkPad
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120327/4938a319/attachment.html
More information about the Dev
