[OpenLayers-Dev] removeExcessTiles doesn't work properly
kikuchan at uranus.dti.ne.jp kikuchan at uranus.dti.ne.jp
Thu May 24 13:30:30 EDT 2012
Dear Eric,
Thank you for your reply.
> This issue sounds like the one reported in
> <https://github.com/openlayers/openlayers/issues/481>.
Yes, you're right, I had exact the same problem.
After that, I'd figured out the tileData[i].tile.draw() caused
"this.layer is null" error.
> This sounds like a good fix. Are your familiar with GitHub? Would you
> make a pull request against the 2.12 branch for that? A new test
> function in tests/Layer/Grid.html for this would also be required.
I'm not familiar with GitHub, and test stuff, but I've tried.
Could you review the commits please?
Thanks in advance.
Kikuchan
More information about the Dev mailing list
