[OpenLayers-Dev] "3D" in OL 2.13
Jani Tiainen redetin at gmail.com
Thu Apr 11 04:23:40 PDT 2013
Hmm, so old pull request but quite same I did. + I added piece of code
to keep dimensionality consistent: If you have 3d geometry and add a
point it will have Z-coordinate (0.0)
And if you have 2d geometry and try to insert 3d point it will force
Z-coordinate to nothing (null in my case).
+ I added bit of code to make geometries consistent if you edit them.
11.4.2013 14:16, Peter Robins kirjoitti:
> note there is already a pr for this
> https://github.com/openlayers/openlayers/pull/344
> On 11 April 2013 11:30, Bart van den Eijnden <bartvde at opengeo.org> wrote:
>> Best way is to create a pull request from your fork.
>> Best regards,
>> Bart
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> On Apr 11, 2013, at 12:24 PM, Jani Tiainen <redetin at gmail.com> wrote:
>> Hi dear devs,
>> I had a need to have "3d" support in OL 2.x-series. With 3d I mean that OL
>> should be able to retain 3rd dimension (Z-coordinate) and end user should be
>> able to manually add Z-coordinate when needed.
>> So far I modified GeoJSON reader/writer to support Z-coordinate (there was
>> some initial work done but it didn't really preserved the data) and a little
>> bit of Geometry.Point and Geometry.MultiPoint to maintain correct
>> dimensiality so there wouldn't be mix of 2d/3d coordinates.
>> Z-coordinate is not taken account in any calculations.
>> How do I proceed with my changes to review (I did fork on a github) so they
>> might become part of OL?
>> Jani Tiainen
>> - Well planned is half done and a half done has been sufficient before...
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Dev mailing list
Jani Tiainen
More information about the Dev mailing list
