[OpenLayers-Dev] OL3, adding mapguide source
Tom Payne
tom.payne at camptocamp.com
Thu Apr 18 12:56:37 PDT 2013
Hi David,
In case you don't want to ask on the ol3-dev list, a quick answer is that
ol3 works in resolutions (map units per pixel, e.g. meters per pixel or
degrees per pixel). You should be able to directly use this value for the
MapGuide source.
A couple of comments:
- scale is 1/resolution, but, from my understanding of reading the MapGuide
specs, the SETVIEWSCALE parameter has an implicit reciprocal so you really
should pass the resolution; ol3 works with resolutions so this should be
fairly straightforward (i.e. no need for getScaleFromResolution or
getResolutionFromScale functions)
- the MapGuide HTTP API seems to be functionally similar to WMS, please
look at the WMS code (in src/ol/source/*wmssource.js) for inspiration!
- in ol3, tiled sources (like WMTS, tiled WMS, OSM, etc.) inherit from a
different base class to image sources (e.g. single image WMS). This means
that whereas as in OL2 you'd write singleTile = true/false in ol3 you'd use
different classes (that can still share common code)
Hope this helps for a starter,
Tom
On 18 April 2013 16:57, Tom Payne <tom.payne at camptocamp.com> wrote:
> Hi David,
> Best to ask this question on the ol3-dev list:
> https://groups.google.com/forum/?fromgroups=#!forum/ol3-dev
> Regards,
> Tom
> On 18 April 2013 15:59, David Hequet <david.hequet at free.fr> wrote:
>> Hi,
>> I'm currently using OL2 with Mapguide layers.
>> Since OL3 is coming i want to contribute by adding MapGuide source for
>> singleimage and tiledimage layer.
>> As mapguide massively use scales (you request single image with center,
>> width, height and scale ,
>> http://trac.osgeo.org/mapguide/wiki/HttpApi/RenderingService#GetMapImage) i
>> wonder if there are helper like ol2's getScaleFromResolution or
>> getResolutionFromScale that can be good starting point for me.
>> thank you
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/OL3-adding-mapguide-source-tp5047985.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Camptocamp SA
> Tom PAYNE
> PSE A
> CH-1015 Lausanne
> +41 21 619 10 13 (direct)
> +41 21 619 10 10 (centrale)
> +41 21 619 10 00 (fax)
Camptocamp SA
Tom PAYNE
PSE A
CH-1015 Lausanne
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130418/d26e5489/attachment.html>
More information about the Dev
