[OpenLayers-Dev] Load a VectorLayer from more than one URL (load several xml files to just one layer)
Ander Pijoan
ander.pijoan at deusto.es
Wed Apr 24 03:48:00 PDT 2013
Hi all
I am using OpenLayers to display some data downloaded from the Overpass
API. Unfortunately some times the amount of data I ask for is quite big so
the Overpass API gets the timeout and I don't receive the answer.
So my idea is to chop the query to Overpass API into some pieces, and load
its results in the same layer.
Currently I am downloading the data like this:
var layer = new OpenLayers.Layer.Vector(Name, {
projection: map.displayProjection,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: *query*,
format: new OpenLayers.Format.OSM()
renderers: ["Canvas", "SVG", "VML"]
I saw that there is some TODOs about making OpenLayers able to download
some WMS layers at a time by inserting a URL array in 'url' parameter.
Is there some good way to do this with the actual code? Something like :
url:* [query1, query2, query3, query4]*,
Which would be the better way to download all this files into just one
layer?
Thank you very much.
Ander Pijoan Lamas
Research Assistant, Deustotech
Computer Science Engineer
University of Deusto
E-mail: ander.pijoan at deusto.es
Phone: +34 664471228
in: http://www.linkedin.com/profile/view?id=162888312
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130424/1a9093ca/attachment.html>
More information about the Dev
