[OpenLayers-Dev] OL 2.13 Modify Feature Example IE8/IE7 : Can't remove vertex
HATRI Aurelien aurelien.hatri at atos.net
Tue Aug 20 08:44:44 PDT 2013
Hi Xavier,
It seems ok to me.
As suggested by Andreas you used the event caught by the drag handler, well done !
I will use your patch from now.
Thanks !
-----Message d'origine-----
De : openlayers-dev-bounces at lists.osgeo.org [mailto:openlayers-dev-bounces at lists.osgeo.org] De la part de Xavier Mamano (jorix)
Envoyé : dimanche 18 août 2013 21:13
À : openlayers-dev at lists.osgeo.org
Objet : Re: [OpenLayers-Dev] OL 2.13 Modify Feature Example IE8/IE7 : Can't remove vertex
Try
https://github.com/jorix/openlayers/commit/8a30a6b802e03ab61e7ccdfa9fd6b1afcb95deab
HATRI Aurelien wrote
> Hello,
> First of all thanks for the good job you guys are doing on the library.
> So my issue is on the modify feature example.
> I can't remove a vertex on a Polygon or on a Line with the IE8 and IE7
> in 2.13. It worked in 2.12.
> I didn't dig very deeply but it seems that now because ModifyFeature
> doesn't use anymore the DragFeature control after a keydown event OL
> can't find anymore the vertex feature's id with getFeatureIdFromEvent.
> It feels IE 8/7 issue here.
> Before I try to push further it will be great if you can find the time
> to look at it.
> Thanks in advance.
> Regards.
> ________________________________
> Ce message et les pi?ces jointes sont confidentiels et r?serv?s ?
> l'usage exclusif de ses destinataires. Il peut ?galement ?tre prot?g?
> par le secret professionnel. Si vous recevez ce message par erreur,
> merci d'en avertir imm?diatement l'exp?diteur et de le d?truire.
> L'int?grit? du message ne pouvant ?tre assur?e sur Internet, la
> responsabilit? du groupe Atos ne pourra ?tre engag?e quant au contenu
> de ce message. Bien que les meilleurs efforts soient faits pour
> maintenir cette transmission exempte de tout virus, l'exp?diteur ne
> donne aucune garantie ? cet ?gard et sa responsabilit? ne saurait ?tre
> engag?e pour tout dommage r?sultant d'un virus transmis.
> This e-mail and the documents attached are confidential and intended
> solely for the addressee; it may also be privileged. If you receive
> this e-mail in error, please notify the sender immediately and destroy
> it. As its integrity cannot be secured on the Internet, the Atos group
> liability cannot be triggered for the message content. Although the
> sender endeavors to maintain a computer virus-free network, the sender
> does not warrant that this transmission is virus-free and will not be
> liable for any damages resulting from any virus transmitted.
> Dev mailing list
> Dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1560.x6.nabble.com/OL-2-13-Modify-Feature-Example-IE8-IE7-Can-t-remove-vertex-tp5072314p5073039.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
Dev mailing list
Dev at lists.osgeo.org
Ce message et les pièces jointes sont confidentiels et réservés à l'usage exclusif de ses destinataires. Il peut également être protégé par le secret professionnel. Si vous recevez ce message par erreur, merci d'en avertir immédiatement l'expéditeur et de le détruire. L'intégrité du message ne pouvant être assurée sur Internet, la responsabilité du groupe Atos ne pourra être engagée quant au contenu de ce message. Bien que les meilleurs efforts soient faits pour maintenir cette transmission exempte de tout virus, l'expéditeur ne donne aucune garantie à cet égard et sa responsabilité ne saurait être engagée pour tout dommage résultant d'un virus transmis.
This e-mail and the documents attached are confidential and intended solely for the addressee; it may also be privileged. If you receive this e-mail in error, please notify the sender immediately and destroy it. As its integrity cannot be secured on the Internet, the Atos group liability cannot be triggered for the message content. Although the sender endeavors to maintain a computer virus-free network, the sender does not warrant that this transmission is virus-free and will not be liable for any damages resulting from any virus transmitted.
More information about the Dev mailing list
