[OpenLayers-Dev] OL 2.13.1 + latest Proj4js (?)
kevint
kevin at rtvision.com
Thu Dec 5 15:49:27 PST 2013
In addition to the wrapper, I had to overwrite the Projection getCode
function:instead of "return this.proj ? this.proj.srsCode : this.projCode;",
or else was having problems with this line in
OpenLayers.Layer.ArcGIS93Rest.getURL:var projWords =
this.projection.getCode().split(":");
Andreas Hocevar-4 wrote
> Hey,You'll have to add the following wrapper before you load projections
> fromspatialreference.org and before you load OpenLayers.js:
> This is all.Andreas.
View this message in context: http://osgeo-org.1560.x6.nabble.com/OL-2-13-1-latest-Proj4js-tp5081636p5093029.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20131205/2a2cd31c/attachment.html>
More information about the Dev
