[OpenLayers-Dev] Chage style for "special marker" in ModifyFeature
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Tue Dec 31 08:33:11 PST 2013
The drag tool (and all other tool created by the control: vertices to drag
...) has a property called "_sketch" (with _sketch = true), If you use a
style with context then could discriminate a different presentation for own
control tool that the points features in the layer.
NOTE: "_sketch" is not a API propierty!
EG: If you use this statement to create the layer in the
http://openlayers.org/dev/examples/modify-feature.html, the drag point will
be shown in red and the points and polygons of the layer blue:
vectors = new OpenLayers.Layer.Vector("Vector Layer", {
renderers: renderer,
styleMap: new OpenLayers.StyleMap({
'default': new OpenLayers.Style(
OpenLayers.Util.applyDefaults(
{fillColor: "${getColor}"},
OpenLayers.Feature.Vector.style['default']
context: {
getColor: function(feature) {
return feature._sketch ? "red" : "blue";
I have developped a non standard code that makes the job simpler,
you can try here:
http://jorix.github.io/OL-Ragbag/examples/modify-feature.html
(to show a tool control do not use the style layer, uses the predefined and
customizable styles from the control)
Xavier
MorlDots wrote
> when use DRAG and etc how to change
> 1) standard style only for this marker
> 2) or establish its image instead of the "special marker"
View this message in context: http://osgeo-org.1560.x6.nabble.com/Chage-style-for-special-marker-in-ModifyFeature-tp5095569p5095933.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
