[OpenLayers-Dev] Towards slick panning and animated zooming
Björn Harrtell bjorn.harrtell at gmail.com
Thu Jan 10 05:37:24 PST 2013
I can't reproduce the flicker issue here, but these are my performance
findings:
No significant difference on desktop (Ubuntu 12.10 64-bit, Chromium
22.0.1229.94) or these Android devices:
Samsung Galaxy Tab 10.1, Android 4.0.4, Chrome 18.0.1025469 (WebKit 535.19)
Nexus 7, Android 4.2.1, Chrome 18.0.1025469 (WebKit 535.19)
A collague of mine reports improvements on the built in browser on
a Samsung Galaxy Tab 2 10.1, though I can't verify that.
Performance is great on an Apple iPad 3, iOS 6 with your latest CSS.
2013/1/9 Andreas Hocevar <ahocevar at opengeo.org>
> Hey Björn,
> your updated example gives me flickers in Desktop Webkit browers. Have
> you also seen my comment on github and my updated example?
> Andreas.
> On Wed, Jan 9, 2013 at 2:09 PM, Björn Harrtell <bjorn.harrtell at gmail.com>
> wrote:
> > I have tested removing the match all rule in the css and it does affect
> Ipad
> > performance significantly in the good direction. On Android however it
> seems
> > to have a slight negative effect. What a mess.... Modified example here:
> http://bjornharrtell.github.com/openlayers/mobile-wmts-vienna/examples/mobile-wmts-vienna.html
> > Den 8 jan 2013 13:54 skrev "Björn Harrtell" <bjorn.harrtell at gmail.com>:
> >> I've tested only with the hosted mobile-wmts-vienna.html example.
> >> The only apparent difference with leaflet I can spot right now is that
> the
> >> rule .olMapViewport, .olMapViewport * cascades to every element below
> the
> >> viewport because of the wildcard, in leaflet it seems these properties
> are
> >> only set on the viewport equivalent dom object. The page you refer to
> has a
> >> comment that might suggest this can cause problems - "Also try not to
> mix
> >> “top/left” with “translate()” this can cause some performance issues as
> >> well(in some cases really bad ones)". I haven't been able to verify any
> of
> >> this yet though, will try to find time to do it asap.
> >> /Björn
> >> 2013/1/8 Andreas Hocevar <ahocevar at opengeo.org>
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130110/92c23afe/attachment.html>
More information about the Dev mailing list
