[OpenLayers-Dev] ANNOUNCEMENT: 2.13 RC7 released
Bart van den Eijnden
bartvde at opengeo.org
Fri Jun 7 02:05:16 PDT 2013
The OpenLayers dev team is proud to announce the 7th release candidate of OpenLayers 2.13! RC7 comes about a day after RC6, and fixes three issues:
* Fix dependencies now that TileManager was used by default https://github.com/openlayers/openlayers/pull/1000 and https://github.com/openlayers/openlayers/pull/1002
* Fix broken tests now that TileManager was used by default https://github.com/openlayers/openlayers/pull/1003
* LayerSwitcher doesnt switch layer entry correctly if Layer is not visible. https://github.com/openlayers/openlayers/pull/997
See https://github.com/openlayers/openlayers/issues?milestone=14&state=closed for details.
We invite you to help us test the 2.13 release candidate! To test 2.13 in your applications, include the following tag in your OpenLayers-powered page:
<script src="http://openlayers.org/api/2.13-rc7/OpenLayers.js"></script>
As always, the source is available at http://openlayers.org/download/. Bug reports can be filed in GitHub at https://github.com/openlayers/openlayers/issues. Make sure to use 2.13-RC7 in the title of the issue (and for developers, please assign those tickets to the 2.13-rc8 milestone).
Thanks!
OpenGeo - http://opengeo.org
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130607/653a2c56/attachment.html>
More information about the Dev
