[OpenLayers-Dev] ol3 - projection issues
Tim-Hinnerk Heuer
th.heuer at gmail.com
Wed May 8 03:58:56 PDT 2013
Yes, I noticed after I've sent it, but Eric had already answered my
question. Thanks anyway though!
Tim-Hinnerk Heuer
Twitter: @geekdenz
Blog: http://www.thheuer.com
On 7 May 2013 02:52, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> You forgot to specify the projection in the View2D settings. See
> http://ol3js.org/en/master/examples/wms-custom-proj.html for a working
> example.
> Also note that OL3 questions should be asked at
> https://groups.google.com/d/forum/ol3-dev.
> Andreas.
> On Fri, May 3, 2013 at 1:51 AM, Tim-Hinnerk Heuer <th.heuer at gmail.com>
> wrote:
> > Hi,
> > I'm wanting to include our WMS-V project into (at least) my development
> > version of ol3. However, I have a couple of issues. The main one is
> that I
> > cannot get our WMS to display. Apparently, it is using the wrong EPSG
> code
> > (as verified by looking at the requests), even though I defined it
> similarly
> > to the custom projection example.
> > We are using EPSG:2193 which is the projection of our data and is not
> > trivial to change.
> > The relevant portion in the HTML is:
> > <script src="
> http://ourenvironment.scinfo.org.nz/js/OpenLayers/proj4js.js"
> > type="text/javascript"></script>
> > <script
> > src="http://ourenvironment.scinfo.org.nz/js/OpenLayers/defs/EPSG2193.js"
> > <script src="loader.js?id=wms-v" type="text/javascript"></script>
> > I have the following code in my example:
> > goog.require('ol.Attribution');
> > goog.require('ol.Map');
> > goog.require('ol.RendererHints');
> > goog.require('ol.View2D');
> > goog.require('ol.layer.ImageLayer');
> > goog.require('ol.projection');
> > goog.require('ol.source.SingleImageWMS');
> > goog.require('ol.source.TiledWMS');
> > var layers = [
> > new ol.layer.TileLayer({
> > source: new ol.source.TiledWMS({
> > url: 'http://maps.scinfo.org.nz/basemaps/wms?',
> > params: {
> > 'LAYERS': 'landscape_eco_painted_relief',
> > 'TILED': true,
> > 'VERSION': '1.1.1'
> > extent: [1000000, 4700000.0000001, 2200000, 6300000]
> > var projection = ol.projection.configureProj4jsProjection({
> > code: 'EPSG:2193',
> > extent: [1000000, 4700000.0000001, 2200000, 6300000],
> > units: 'm'
> > var map = new ol.Map({
> > //renderer: ol.RendererHint.CANVAS,
> > renderer: ol.RendererHint.DOM,
> > projection: projection,
> > layers: layers,
> > target: 'map',
> > view: new ol.View2D({
> > center: [1600000, 5500000],
> > zoom: 4
> > However, it doesn't work as expected. The requests are going to for
> > example:
> http://maps.scinfo.org.nz/basemaps/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&WIDTH=256&HEIGHT=256&LAYERS=landscape_eco_painted_relief&TILED=true&STYLES=&SRS=EPSG%3A3857&BBOX=2504688.542848654%2C5009377.085697312%2C5009377.08569731%2C7514065.628545968
> > which is obviously the wrong projection.
> > Note: When I zoom out a lot, I can see a faint hint of New Zealand, so it
> > seems like it could work.
> > Any help would be much appreciated.
> > Regards,
> > Tim
> > Tim-Hinnerk Heuer
> > Twitter: @geekdenz
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130508/d4ceb73c/attachment.html>
More information about the Dev
