[OpenLayers-Dev] 2.12-dev - Delay in tile hiding
Tim-Hinnerk Heuer
th.heuer at gmail.com
Tue May 14 19:43:55 PDT 2013
To answer my own question:
I found that this can be worked around by changing the
removeBackBufferDelay
in the WMS Options:
var options = {/*...*/}
options.removeBackBufferDelay = 0;
OpenLayers.Layer.WMS(description, url, params, options);
The delay is supposed to fix a flicker, which I didn't notice. So, if you
have flicker problems, the default is 2500, but I would make it less than
that.
Comments welcome.
Cheers,
Tim
Tim-Hinnerk Heuer
Twitter: @geekdenz
Blog: http://www.thheuer.com
On 15 May 2013 13:09, Tim-Hinnerk Heuer <th.heuer at gmail.com> wrote:
> To clarify:
> I tried looking into the tweening of the zoom and turning it off and
> playing with the settings. I even turned off tweening for panning. But both
> things didn't change this behavior while the tweening was visibly off.
> Any hints?
> Cheers,
> T
> Tim-Hinnerk Heuer
> Twitter: @geekdenz
> On 15 May 2013 13:07, Tim-Hinnerk Heuer <th.heuer at gmail.com> wrote:
>> Hi,
>> We have a problem with the latest development version of OL. While it
>> fixed the problem in IE10 where the map was tearing, it now has another
>> problem:
>> When zooming, our top level layers' tiles are hidden with a significant
>> amount of delay. This results in it feeling very slow even though our WMS
>> delivery is very fast. In fact you can see the zoomed in tiles while the
>> fuzzy tiles that are at a smaller scale are still displayed. After about
>> 3-5 seconds they get hidden correctly, but I think they should be hidden
>> already at the time the larger scale is displayed.
>> I hope this makes sense as I find it hard to put this into words.
>> Any help much appreciated. I don't mind fixing it myself, but I don't
>> know where to even look for this.
>> Thanks,
>> Tim
>> Tim-Hinnerk Heuer
>> Twitter: @geekdenz
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130515/7bfdd66f/attachment.html>
More information about the Dev
