[OpenLayers-Dev] Testing
Andreas Hocevar
ahocevar at opengeo.org
Sun May 19 04:20:44 PDT 2013
thanks for willing to help out! That pull request needs unit tests. To get
started, look at the contents of the tests/ folder in the repository. The
html files in there contain test cases. It should be rather
self-explanatory how to write tests with TestAnotherWay (the test framework
used), if you are familiar with the concept of unit tests.
Andreas.
On Fri, May 17, 2013 at 11:24 PM, Michael Ryan <mr at mry4n.net> wrote:
> Hi,
> I'd like to help get the following patch committed by doing testing on it.
> Can someone direct me to documentation on how to do this testing? I've
> found old info from trac.osgeo and info for OL3 on github. But I'm not sure
> what I'm supposed to do for OL 2.1x.
> Thanks,
> Mike
> https://github.com/openlayers/openlayers/pull/174#ref-issue-6562621
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20130519/153b251a/attachment.html>
More information about the Dev
