[OpenLayers-Dev] Testing
Andreas Hocevar
ahocevar at opengeo.org
Thu May 23 15:20:13 PDT 2013
Right now you are calling logEvent() once, and you're doing so when
you define the listener:
map.events.on({featureclick: logEvent()});
Instead, this should read
map.events.on({featureclick: logEvent});
Andreas.
On Thu, May 23, 2013 at 4:30 PM, Michael Ryan <mr at mry4n.net> wrote:
> I checked that out, but that didn't seem to be it. I noticed in
> buttonclick.html that it just uses onload=init() in the body tag and doesn't
> call init() in any of the test functions.
> However, it seems ilke I have to add the featureclick event and assign it a
> function with parantheses, whereas running it in the html requires no
> parentheses.
> So the test function now looks like this:
> function test_onClick23(t) {
> t.plan(1);
> logevt = [];
> events = map.events;
> lonlat = new OpenLayers.LonLat(0,0);
> pixel = map.getPixelFromLonLat(lonlat);
> trigger('mousedown', pixel);
> trigger('mouseup', pixel);
> t.eq(logevt.length, 2, "testing log length");
> t.wait_result( 3 );
> and the logEvent function is:
> function logEvent(e) {
> //alert("Does this happen?");
> logevt.push(e);
> https://github.com/m1k3ry4n/openlayers/blob/master/tests/Events/featureclick.html
> The problem is that no matter how many features I add, the logevt array is
> length 1.
> I tried using the t.wait_result() function, taking a wild stab that since a
> featureclick event gets fired for each feature that maybe there's some
> timing issue that gets taken care of when you view featureclick.html but
> needs to be accounted for in testing. Unfortunately, t.wait_result() didn't
> change anything.
> -Mike
> On May 23, 2013, at 3:26 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> I think the problem is that your init() function won't be called when the
> page is loaded by the test runner. So you'll have to call init() from the
> test function (test_onClick12 in the current code).
> Andreas.
> On Thu, May 23, 2013 at 12:33 PM, Michael Ryan <mr at mry4n.net> wrote:
>> Thanks for all the help, Andreas.
>> I'm pretty sure I can figure the contrib stuff out.
>> At the moment, I'm hitting a wall with why a very simple test works if I
>> just run the featureclick.html page, but not when I run the test function:
>> When I run the html page the logevt array has length 2. In the test, it's
>> length 0. Yet I'm running the exact same code.
>> I know this is taking a while and I may be missing the 2.13 deadline, but
>> I'll keep plugging away at this til I get it right.
>> -Mike
>> On May 22, 2013, at 10:02 PM, Andreas Hocevar <ahocevar at opengeo.org>
>> wrote:
>> Hey Michael,
>> you should find all information on how to submit code here:
>> http://trac.osgeo.org/openlayers/wiki/HowToContribute. You will want to
>> create a pull request, as explained here:
>> http://trac.osgeo.org/openlayers/wiki/CreatingPatches.
>> I hope this helps.
>> Andreas.
>> On Wed, May 22, 2013 at 9:34 AM, Michael Ryan <mr at mry4n.net> wrote:
>>> Thank you Andreas for clearing up that I should assign events like so:
>>> events = map.events
>>> The other part of this is that you have specify that the event you are
>>> triggering is a left-click.
>>> By tracing the code you see that you need to set the "which" attribute to
>>> 1 in the object passed to triggerEvent(), otherwise onClick in
>>> featureclick.js ignores the event.
>>> So, this is what my code should have looked like:
>>> events.triggerEvent( 'mousedown', {xy: new OpenLayers.Pixel(0,0), which:
>>> 1}, map);
>>> events.triggerEvent('mouseup', {xy: new OpenLayers.Pixel(0,0), which: 1},
>>> map);
>>> I'm assuming I can get tests written today. Although, I'm not exactly
>>> clear how to submit them. If anyone wants to clue me in to that procedure
>>> I'd appreciate it.
>>> -Mike
>>> On May 21, 2013, at 5:21 PM, Michael Ryan <mr at mry4n.net> wrote:
>>> While I've understood I need to use trigger() somehow, I have been
>>> unsuccessful in implementing it.
>>> I was using test for buttonclick as a reference:
>>> https://github.com/openlayers/openlayers/blob/master/tests/Events/buttonclick.html
>>> I would have assumed that within the context of the featurclick example
>>> https://github.com/openlayers/openlayers/pull/174/files
>>> I could have used something like
>>> events = OpenLayers.Events(map, document.getElementById("map"));
>>> events.triggerEvent({type: 'mousedown', xy: new OpenLayers.Pixel(0,0)},
>>> map); events.triggerEvent({type: 'mouseup', xy: new OpenLayers.Pixel(0,0)},
>>> map);
>>> But, apparently, that's wrong.
>>> Am I trying to do something that isn't possible? I'm assuming I'm just
>>> implementing it wrong. Any thoughts?
>>> -Mike
>>> On May 20, 2013, at 5:04 PM, Michael Ryan <mr at mry4n.net> wrote:
>>> I'll answer my question about triggering a buttonclick by saying, it
>>> looks like you use trigger() which takes coordinates as an argument as in
>>> this test:
>>> https://github.com/drewwells/openlayers/blob/master/tests/Control/Measure.html
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Dev mailing list
> Andreas Hocevar
Andreas Hocevar
More information about the Dev
