[OpenLayers-Dev] OL 2.13.1 + latest Proj4js (?)
Andrea Battisti
battisti at actgate.com
Thu Oct 3 06:28:54 PDT 2013
Hello,
Looks like that the latest version of Proj4js from:
https://github.com/proj4js/proj4js
has a slightly different API then before, and indeed it does not seem to
work with the plain OL 2.13.1.
Question: is there a patch available to use OL against the new Proj4js?
If not, which is the best way to make it compatible?
As far as I see the code to adapt will be the OpenLayers.Projection
class in Projection.js; is that enough? are there other changes needed
from the OL perspective?
Thanks in advance!
Ing. Andrea Battisti
More information about the Dev
