[OpenLayers-Dev] .py is not oppened
    Mihkel Oviir
    mihkel.oviir at gmail.com
    Wed Jun 11 22:43:09 PDT 2014
It is hard to predict on given information why you don't see the map. Do
you have dom element with id="map", do you have width and height specified
on that element in css, do you add layers to map, do you set some view to
map (setCenter or setExtent)?
Don't you see map at all? No zoom controls etc. or just you do not see
specified layers?
regards,
Mihkel
2014-06-11 21:33 GMT+03:00 Franklin Garzón <franklin.garzon at gtskybase.com>:
> Good day community, maybe any peple can help us with this.
> We can't to see the map with this version, what is wrong?  (thanks for your
> help)
> map = new OpenLayers.Map("map",{
>             projection: "EPSG:900913",
>         displayProjection: "EPSG:4326",
>                 numZoomLevels: 19});
> var gwc = new OpenLayers.Layer.WMS(
>                 "Global Imagery",
>                 "http://maps.opengeo.org/geowebcache/service/wms",
>                 {layers: "bluemarble"}
> var vmap = new OpenLayers.Layer.WMS(
>                                 "Mapa Digital",
> "http://www.tracklink.ec:8080/cgi-bin/tilecache.py",
>                                         layers: "basic",
>                                         reaspect: false,
>                                         format: 'image/png',
>                                         transparent: true
>                                         isBaseLayer: true,
>                                         numZoomLevels: 19,
>                                         singleTile: false,
>                                         ratio: 1,
>                                         buffer: 0,
>                                         displayInLayerSwitcher:true
> Cordialmente,
> Franklin Garzón
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140612/0a24e044/attachment.html>
More information about the Dev
