[OpenLayers-Dev] ESRI // WCS DescribeCoverage 1.1.0
Bart van den Eijnden
bartvde at boundlessgeo.com
Mon May 26 01:32:14 PDT 2014
Hey Chris,
the way to verify who is right is to look at the schema, so:
http://schemas.opengis.net/wcs/1.1/wcsDescribeCoverage.xsd
it defines:
xmlns:ows="http://www.opengis.net/ows/1.1”
so this is the correct namespace URI to use.
Best regards,
Bart
Front-end Developer | Boundless
@boundlessgeo
On 26 May 2014, at 10:30, Christopher Eykamp <christopher.eykamp at tudor.lu> wrote:
> Hi Tim,
> Thanks for the reply. I am less familiar with the standards than you are, so can you tell me how one can determine that the second schema is for WCS 1.1.0, and not the first? From the names, I would conclude that the first is correct, and that the second is... also correct?
> In any event, I will need to find a way to parse this document (I don't control the server, and our partner who does is probably unable to resolve things on their end). I will look into Bart's suggestion to see if that offers a way forward.
> Thanks!
> Chris
> On 05/23/2014 06:25 PM, Timothy Astle wrote:
>> I believe you've hit an oddity in the WCS schemas.
>> Look at this one:
>> http://schemas.opengis.net/wcs/1.1.0/wcsDescribeCoverage.xsd
>> Now look at this one:
>> Do you see a difference in the ows namespace? From what I recall, the second one is correct. A few years ago I was in a similar situation. I'm thinking ArcGIS Server might be generating XML using the wrong schemas.
>> So I believe OL is correct and the "problem" is with ArcGIS Server, leading from the OGC schema confusion. I'd love to know the history behind it.
>> Do you have control over the ArcGIS Server instance? It could be something you want to bring up with ESRI.
>> Cheers,
>> Tim
>> On 23/05/2014 12:19 PM, Christopher Eykamp wrote:
>>> Hello,
>>> I am getting the attached response from an ArcGIS WCS server, with request DescribeCoverage and protocol version 1.1.0. OpenLayers (latest 1.x from GitHub) cannot retrieve the Title or Abstract attributes because the namespaces referenced in the OpenLayers.Format.WCSDescribeCoverage.v1_1_0 object conflict with what is referenced in the document.
>>> Specifically, the OpenLayers namespaces object includes this line:
>>> ows: "http://www.opengis.net/ows/1.1"
>>> This in turn is used to generate a namespaceAlias lookup, which will return "ows" when looking up "http://www.opengis.net/ows/1.1". However, in this case, I need "ows" to be mapped to "http://www.opengis.net/ows". If I make that change in the namespaces definition, tests break. Unfortunately, given the way the aliases are defined, I cannot add a second namespace that maps to "ows", which might fix my problem.
>>> I am unsure how to proceed. I can't tell if I am encountering a misbehaving server, or if this is just a limitation of the way OpenLayers is architected (hard-coded namespaces that can only have one namespace map to a given alias). Or have I misunderstood something at a more fundamental level?
>>> Thanks for your advice!
>>> Chris
>>> <CoverageDescriptions xmlns="http://www.opengis.net/wcs/1.1" xmlns:ows="http://www.opengis.net/ows" xmlns:owcs="http://www.opengis.net/wcs/1.1/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xsi:schemaLocation="http://www.opengis.net/wcs/1.1 ../wcsDescribeCoverage.xsd http://www.opengis.net/wcs/1.1/ows ../owsDataIdentification.xsd"><CoverageDescription><ows:Title>OSDATA.OS_25K_RASTER_1</ows:Title><ows:Abstract/><Identifier>1</Identifier><Domain><SpatialDomain><ows:BoundingBox crs="urn:ogc:def:crs:OGC::imageCRS" dimension="2"><ows:LowerCorner>0 0</ows:LowerCorner><ows:UpperCorner>16273 8848</ows:UpperCorner></ows:BoundingBox><ows:BoundingBox crs="urn:ogc:def:crs:EPSG::4326"><ows:LowerCorner>-2.4975225300277217 57.00034657412791</ows:LowerCorner><ows:UpperCorner>-2.0000237693585987 57.270861907368726</ows:UpperCorner></ows:BoundingBox><GridCRS><GridBaseCRS>urn:ogc:def:crs:EPSG::4326</GridBaseCRS><GridOrigin>-2.4975072449484337 57.27084662228944</GridOrigin><GridOffsets>3.057015857620272e-005 -3.0570158576202496e-005</GridOffsets></GridCRS></SpatialDomain></Domain><Range><Field><Title>Field_1</Title><Abstract>Field_1</Abstract><Identifier>Field_1</Identifier><Definition><owcs:AnyValue/></Definition><NullValue>256</NullValue><NullValue>256</NullValue><NullValue>256</NullValue><owcs:InterpolationMethods><owcs:DefaultMethod>nearest</owcs:DefaultMethod><owcs:OtherMethod>bilinear</owcs:OtherMethod><owcs:OtherMethod>bicubic</owcs:OtherMethod></owcs:InterpolationMethods><Axis identifier="BAND"><AvailableKeys><Key>1</Key><Key>2</Key><Key>3</Key></AvailableKeys><owcs:DataType>Byte</owcs:DataType></Axis></Field></Range><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedCRS>urn:ogc:def:crs:EPSG::4326</SupportedCRS><SupportedFormat>image/GeoTIFF</SupportedFormat><SupportedFormat>image/NITF</SupportedFormat><SupportedFormat>image/HDF</SupportedFormat><SupportedFormat>image/PNG</SupportedFormat></CoverageDescription></CoverageDescriptions>
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Tim Astle
>> Development Manager
>> Web Technologies
>> CARIS
>> 115 Waggoners Lane
>> Fredericton, New Brunswick
>> Canada E3B 2L4
>> Tel: +1.506.458.8533 Fax: +1.506.459.3849
>> www.caris.com
>> CARIS 2014
>> June 2-5, 2014 | Brest, France | 2-5 juin, 2014
>> Join us in France at CARIS 2014 as we focus on Developing the Blue Economy. www.caris.com/caris2014/
>> Venez nous rejoindre en France pour CARIS 2014 et appuyons ensemble l'Économie Bleue. www.caris.com/caris2014-fr/
>> Download your free copy of CARIS Easy View today!
>> www.caris.com/easyview
>> _________________________________________________________________________
>> This email and any files transmitted with it are confidential and intended only for the addressee(s). If you are not the intended recipient(s) please notify us by email reply. You should not use, disclose, distribute or copy this communication if received in error.
>> Any views or opinions expressed in this email are solely those of the author and do not necessarily represent those of the company. No binding contract will result from this email until such time as a written document is signed on behalf of the company.
>> Dev mailing list
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140526/524d0f75/attachment.html>
More information about the Dev
