[OpenLayers-Dev] Lost scope in tileUrlFunction when extending ol.source.VectorTile (MVT)
Roman Zoller roman.zoller at camptocamp.com
Thu Oct 12 05:48:05 PDT 2017
As far as I understand, the ol.source.VectorTile class wasn't specifically
designed to have tileUrlFunction as a function that can be overriden and
that will be called with a specific this context.
I think the general idea is that you can just pass any function as
options.tileUrlFunction, and it just happened to be called with a this
context of the class before version 4.2.0, but I guess this was never
really an intended feature.
For your specific issue, I think you could rename the function in your
class to avoid confusion, e.g.
ol.source.GWCVT.prototype.defaultTileUrlFunction =
    function(tileCoord, pixelRatio, projection) {
and then pass it as options.tileUrlFunction to the super class in your
constructor, with correctly bound this:
ol.source.GWCVT = function(options) {
  var tileUrlFunction = options.tileUrlFunction ||
this.defaultTileUrlFunction.bind(this);
  ol.source.VectorTile.call(this, {
    tileUrlFunction: tileUrlFunction,
Hope that helps!
Cheers,
Roman
On Thu, Oct 12, 2017 at 2:33 PM, Christian Mayer <ml-cm at meggsimum.de> wrote:
> Hi again,
> here is some more information in addition to my previous mail:
> The problem occurs for VectorTiles in GeoJSON format as well. So there
> must be a more general problem with extending the
> ol.source.VectorTile (or the way I do it).
> The change / problem seems to be introduced with Version 4.2.0. With
> version 4.1.1 everything works as expected.
> Cheers
> Chris
> On 12.10.2017 13:45, Christian Mayer wrote:
> Hi all,
> I extended the class ol.source.VectorTile in order to load VectorTiles in
> different formats (GeoJSON and MVT) from a local GWC cache. While upgrading
> from OpenLayers v3.20 to OpenLayers v4.x it seems that for MVT the scope in
> the "tileUrlFunction" gets lost. It seems to be "window". For GeoJSON-based
> VectorTiles everything is still running fine.
> Below you find the crutial parts of my class:
> ol.inherits(ol.source.GWCVT, ol.source.VectorTile);
> ol.source.GWCVT.prototype.tileUrlFunction =
> // here 'this' becomes 'window' in the second call
> // assembling the URL
> ol.source.GWCVT.prototype.setTileUrlFunction = function(tileUrlFunction) {
>   ol.source.VectorTile.prototype.setTileUrlFunction.call(this,
> tileUrlFunction);
> Thanks for any hint!
> Cheers
> Chris
> Dev mailing listDev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20171012/f89a0154/attachment.html>
More information about the Dev mailing list
