[OpenLayers-Dev] MVT: Problems with missing pbf files
Andreas Hocevar
andreas.hocevar at gmail.com
Thu Oct 19 08:17:17 PDT 2017
Hey Chris,
this sounds like a bug. Can you please create a ticket and provide a
codepen that shows the issue?
Thanks,
Andreas.
On Thu, Oct 19, 2017 at 5:11 PM, Christian Mayer <ml-cm at meggsimum.de> wrote:
> Hi OL-Devs,
> I have a setup with a VectorTile layer based on Mapbox Vector Tiles (created
> with GeoServer / Geowebcache). To save time at transferring the pbf-files to
> the target environment all empty pbf-files were deleted. This results in
> HTTP 404s (of course) when OpenLayers tries to load the missing tiles.
> I expected that this won't bring any problems and that OL is just ignoring
> them. But unfortunately a JS-exception occurs if in the current map-exent is
> one of the missing tiles.
> It seems that the "tileProjection" is undefined for the given "sourceTile",
> so the operation tileProjection.getUnits() fails, see here [1]. So it seems
> that the missing tile is not ignored in the code and due to the lack of
> information the rendering process fails.
> If I add an emtpy pbf-file, so no HTTP 404 occurs anymore, the exception is
> gone. Even though no more information is provided (from my humble point of
> view).
> So here are some questions: Can someone confirm this behavior? Is this
> wanted behavior for some reasons? Or is this even a bug or an edge case?
> I am using OpenLayers v4.3.4.
> Thanks in advance for any hint / help / clarification.
> Cheers
> Chris
> [1]
> https://github.com/openlayers/openlayers/blob/v4.3.4/src/ol/renderer/canvas/vectortilelayer.js#L139
> Dev mailing list
> Dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
