[OpenLayers-Trac] Re: [OpenLayers] #2819: Format.XML could add
xmlns attributes by default
trac-20090302 at openlayers.org
Fri Dec 3 11:35:59 EST 2010
#2819: Format.XML could add xmlns attributes by default
Reporter: bartvde | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Format.XML | Version: 2.10 RC1
Keywords: | State: Review
Comment(by sonxurxo):
Replying to [comment:3 bartvde]:
> @sonxurxo: did you do any checks on speed? I.e. is there a noticeable
performance decrease because of this patch or not?
@bartvde: I didn't do them before, I just did them now 'on demand'. I
tested the examples/xml.html file, and what I did is (just to clarify, I
don't know if you have other methods), with firebug, profile the
consecutive execution of all the methods linked in the example. The times
(I executed the test three times) spent by XML.write() function is:
RUN 1 RUN 2 RUN 3
- without the patch: 1.853ms 2.14ms 2.423ms
- with the patch: 1.847ms 2.393ms 2.019ms
So I think there's no special relevance, have you experience some?
Ticket URL: <http://trac.openlayers.org/ticket/2819#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
