[OpenLayers-Trac] Re: [OpenLayers] #2591: mousedown event handler
method fails to call checkModifiers
trac-20090302 at openlayers.org
Sat Dec 4 13:52:08 EST 2010
#2591: mousedown event handler method fails to call checkModifiers
Reporter: tarmath | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Path | Version: 2.8
Keywords: keyMask | State:
Comment(by mgleahy):
I've run into this problem as well (in 2.10). I think this also needs to
be added to the mouseup event in the Path handler. I my own solution,
I've created subclasses that also include this for the click event in the
Point handler, and the dblclick event for the Path/Polygon handlers.
I've also included a check for the rightclick event:
[CODE]
// check keyboard modifiers
if(!this.checkModifiers(evt) ||
!OpenLayers.Event.isRightClick(evt)) {
return true;
[/CODE]
Ticket URL: <http://trac.openlayers.org/ticket/2591#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
