[OpenLayers-Trac] [OpenLayers] #2982: Document that the script name
MUST be OpenLayers.js, or ImgPath must be set
trac-20090302 at openlayers.org
Thu Dec 16 16:59:00 EST 2010
#2982: Document that the script name MUST be OpenLayers.js, or ImgPath must be set
Reporter: slinkp | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: documentation | Version: SVN
Keywords: | State:
I wanted to make a single-file build of the trunk and name it after the
revision number, eg. OpenLayers-r12345.js.
Everything seemed to work except that my control images went 404.
It took me quite a long time to solve this. Poking around the source and
searching for related bugs, I eventually figured out how it works - the
default is to use _getScriptLocation() and find an img/ directory
relative to that, but _getScriptLocation() assumes that the script name is
exactly OpenLayers.js.
That's fine, especially because there's a feature tailor-made for this
case - you can set OpenLayers.ImgPath - but I'm not sure if or where this
is documented.
http://docs.openlayers.org/search.html?q=OpenLayers.ImgPath&check_keywords=yes&area=default
turns up nothing.
Suggestion: add text to http://docs.openlayers.org/library/deploying.html
something along the lines of:
"If you name your build anything other than OpenLayers.js, note that
OpenLayers will not be able to automatically find the img/ or theme/
directories. In this case, you should set OpenLayers.ImgPath to the
relative base URI at which the img/ directory will be served. You should
probably also include style.css in your html explicitly."
Related wontfix bug: #1932
Ticket URL: <http://trac.openlayers.org/ticket/2982>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
