[OpenLayers-Trac] Re: [OpenLayers] #2754: WMS tiles not loading when map region crossing international date line(IDL)
OpenLayers trac-20090302 at openlayers.org
Tue Dec 21 18:30:33 EST 2010
 Reporter:  Senthil   |       Owner:  euzuro
     Type:  feature   |      Status:  new
 Priority:  critical  |   Milestone:  2.11 Release
Component:  Layer     |     Version:  2.9
 Keywords:            |       State:  Review
Changes (by senthil):
 * cc: senthil (added)
  * owner:  => euzuro
  * state:  => Review
  * component:  Tile.WFS => Layer
  * priority:  minor => critical
Comment:
 Finally i got chance to spent time on this issue as earlier workaround did
 not work well with GWC & geoserver layergroup.
 Root cause of this issue in Openlayers wrapDateLine fix which not
 considered tolerance value for both sides.
 I modified the Layer.js (line 1292) code segment
         if (this.wrapDateLine) {
             // wrap around the date line, within the limits of rounding
 error
             var wrappingOptions = {
                 'rightTolerance':this.getResolution()
             bounds = bounds.wrapDateLine(this.maxExtent, wrappingOptions);
 As below:
 error
                 'rightTolerance':this.getResolution(),
                 'leftTolerance':this.getResolution()
 Then it works fine. Pls include this fix to next release as prefer to use
 realase version as it helps to get other fixes and new features.
Ticket URL: <http://trac.openlayers.org/ticket/2754#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
