[OpenLayers-Trac] [OpenLayers] #2990: MousePosition Control returns
2, 2 at upper left corner of the map
trac-20090302 at openlayers.org
Tue Dec 28 11:57:01 EST 2010
#2990: MousePosition Control returns 2,2 at upper left corner of the map
Reporter: sanojr | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
I am trying to use the OpenStreetMap and was trying to locate the pixel
location on the map using lat and lon but was returning me incorrect
values. Later i found that when i place the mouse at upper left corner of
the map i am receiving 2,2 instead of 0,0.
As mentioned in the examples, this could be a bug. If so, please do fix
and if their is a mistake in the way i have used the functionality then
please let me know on how it should be corrected.
Below is the simple html code that i am using
<html>
<head>
<title>OpenLayers Demo</title>
<style type="text/css">
html, body, #map {
width: 500px;
height: 500px;
margin: 0;
</style>
<script src="OpenLayers.js"></script>
<script>
var map;
function init() {
map = new OpenLayers.Map('map');
var mapnik = new OpenLayers.Layer.OSM();
map.addLayer(mapnik);
map.setCenter(new OpenLayers.LonLat(13.41,52.52) // Center of the
map
.transform(
new OpenLayers.Projection("EPSG:4326"), // transform from WGS
1984
new OpenLayers.Projection("EPSG:900913") // to Spherical
Mercator Projection
), 15 // Zoom level
map.events.register("mousemove", map, function(e) {
var position = this.events.getMousePosition(e);
OpenLayers.Util.getElement("coords").innerHTML = position;
</script>
</head>
<body onload="init();">
<table>
<tr>
<td>
<div id="map" class="smallmap"></div>
<div id="basicMap"></div>
</td>
<td valign="top">
<div id="coords"></div>
</td>
</tr>
</table>
</body>
DIV.olControlMousePosition {
BOTTOM: 0em; DISPLAY: block; FONT-FAMILY: Arial; FONT-SIZE:
smaller; RIGHT: 3px
</style>
</html>
let me know if you need more information.
Regards,
Sanoj
Ticket URL: <http://trac.openlayers.org/ticket/2990>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
