[OpenLayers-Trac] Re: [OpenLayers] #2247: getMousePosition off due
to borders and relative/absolute positioning
trac-20090302 at openlayers.org
Mon Nov 1 15:07:03 EDT 2010
#2247: getMousePosition off due to borders and relative/absolute positioning
Reporter: chrelad@… | Owner: euzuro
Type: bug | Status: new
Priority: critical | Milestone: 2.11 Release
Component: Events | Version: 2.8
Keywords: mouse position getMousePosition offset click coordinates border relative position | State: Review
Changes (by ahocevar):
* state: Needs More Work => Review
Comment:
The issue reported here turned out to be a serious rabbit hole:
* !OpenLayers.Util.pagePosition returns incorrect positions if a map div
with {{{position: relative}}} or {{{position: absolute}}} is nested in a
stack of containers that have borders. The attached patch fixes this issue
by replacing !OpenLayers.Util.pagePosition with a function inspired by
http://code.google.com/p/doctype/wiki/ArticlePageOffset, which uses code
from Yahoo's getXY method.
* The map div's border - set to 1px in all our examples except
fullScreen.html - causes an offset of 1px. Thicker borders (like in
attachment:mouseoffset.html) increase the offset. This is independent of
the positioning method of the map div. The patch fixes this by attaching
the Events instance to the map's viewPortDiv instead of the div. This is
perfectly sane because the map div just serves as a container.
* The page's scroll offset only works correctly due to adjustments in
!OpenLayers.Event.getMousePosition. By adding a new
!OpenLayers.Util.getViewportElement function, which determines the
viewport element (which page position calculations are based on) the same
way the new pagePosition method does, we now have a reliable base for
scrollTop and scrollLeft. This function uses code taken from
http://code.google.com/p/doctype/wiki/ArticleClientViewportElement.
The patch adds a new manual test (tests/manual/page-position.html), which
reveals all issues. Unit tests continue to pass in FF3.6, Safari 5 and
IE8. The manual test displays fine in the same browsers, and also in Opera
10.6 and Chrome 7.
Thanks for any review.
Ticket URL: <http://trac.openlayers.org/ticket/2247#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
