[OpenLayers-Trac] Re: [OpenLayers] #2926: Select control do not unselect last feature if is NOT in the first layer (was: Select control do not unselect last feature if is in the first layer)
OpenLayers trac-20090302 at openlayers.org
Fri Nov 12 08:59:48 EST 2010
 Reporter:  PadovaBoy              |       Owner:  tschaub
     Type:  bug                    |      Status:  new
 Priority:  major                  |   Milestone:  2.11 Release
Component:  Control.SelectFeature  |     Version:  2.10
 Keywords:                         |       State:
Comment(by PadovaBoy):
 Replying to [comment:1 pgiraud]:
 > Can you please provide a complete test case, or a bit of code so that
 we're able to reproduce the bug ?
 > Thanks.
 Sure, for now: thank u for the attention.
 PS: you can see immediately the problem in this line (from the original
 code):
 for (var l = 0; l < layers.length; ++l) {
 if (layer.selectedFeatures.length === 0) { return; }
 in the loop, on the first execution, it check the length of the selected
 features...if is 0 exit..so if the previously selected feature reside in
 the second layer will never unselect..
Ticket URL: <http://trac.openlayers.org/ticket/2926#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
