[OpenLayers-Trac] [OpenLayers] #2931: Problems with parsing GPX-Files
OpenLayers trac-20090302 at openlayers.org
Mon Nov 15 05:58:06 EST 2010
 Reporter:  laberlaib  |       Owner:
     Type:  bug        |      Status:  new
 Priority:  minor      |   Milestone:  2.11 Release
Component:  general    |     Version:  2.10
 Keywords:             |       State:
 Hello,
 when trying to parse some GPX-Files i found out about the following:
 If a GPX-file contains a waypoint with an empty <name>-node, the GPX-file
 will not be parsed porperly.
 I use the following code to create the layers and draw the files:
 var gpxLayer = new OpenLayers.Layer.GML("layername", "filename.gpx" , {
                         format: OpenLayers.Format.GPX,
                                 styleMap: new OpenLayers.StyleMap({
                                         strokeColor: "green", strokeWidth:
 4,
                                     strokeDashstyle:
 "solid",strokeOpacity: 0.8
                                 projection: new
 OpenLayers.Projection("EPSG:4326")
                 map.addLayer(gpxLayer);
 I got about 40 routes i want to draw. All the tracks i couldn't draw ended
 with
         <wpt lat="xx.xx" lon="yy.yy">
                 <name></name>
         </wpt>
 After deleting these last lines in the file, everything worked out well.
 OS: WinXP;
 Browsers: FF 3.6.12 // IE 7;
 OL-Version: Link to hosted version
 I could not find any solution by searching the web.
 laberlaib
 PS: it is the first time i use a ticket-based system to report a bug, i
 hope i did it right.
Ticket URL: <http://trac.openlayers.org/ticket/2931>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
