[OpenLayers-Trac] Re: [OpenLayers] #2842: Improving SOS v1.0.0
specification support in SOSGetObservation format
trac-20090302 at openlayers.org
Tue Nov 16 04:13:22 EST 2010
#2842: Improving SOS v1.0.0 specification support in SOSGetObservation format
Reporter: sonxurxo | Owner: bartvde
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Format | Version: 2.10
Keywords: SOSGetObservation, Format | State: Review
Comment(by bartvde):
Hi sonxurxo, do you have an output example of a GetObservation result with
geometries in there (maybe also a FeatureCollection)? Then I can write
some tests. The featureMember parser function should not be necessary
since it is part of GML.Base already.
I'll attach a new patch shortly with a few minor changes to your patch,
and if you can confirm things still work okay for you, I can commit this
code.
Thanks for this great contribution! Good to see someone make improvements
to the code, and someone who knows about SOS :-) !
Ticket URL: <http://trac.openlayers.org/ticket/2842#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
