[OpenLayers-Trac] Re: [OpenLayers] #2933: OpenLayers runs HTML5-incompatible script loading code if the UA string doesn't contain "Safari" or "MSIE"
OpenLayers trac-20090302 at openlayers.org
Wed Nov 17 08:25:12 EST 2010
 Reporter:  hsivonen  |       Owner:
     Type:  bug       |      Status:  new
 Priority:  critical  |   Milestone:  2.11 Release
Component:  general   |     Version:  2.10
 Keywords:            |       State:  Review
Comment(by erilem):
 Replying to [comment:5 hsivonen]:
 > In WebKit, you are already using document.write and script aren't
 loading in parallel, so there'd be no load time increase compared to the
 status quo.
 > In Firefox trunk right now, using document.write would increase load
 time compared to your current setup in Firefox 3.6. However,
 document.written scripts will load in parallel once
 https://bugzilla.mozilla.org/show_bug.cgi?id=543062 is fixed.
 > Contrary to what I wrote in http://hsivonen.iki.fi/script-execution/ ,
 the current plan (but not promise) is to make document.written scripts
 load in parallel in Firefox 4. (This retargeting to Firefox 4 is a new
 development after I filed this OpenLayers bug. The motivation of the
 retargeting to Firefox 4 is to make it possible for OpenLayers to move to
 cross-browser-compatible code without losing parallel loads in Firefox.)
 > Your patch looks good to me.
 Thanks a lot for your support, and the thorough explanations.
Ticket URL: <http://trac.openlayers.org/ticket/2933#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
