[OpenLayers-Trac] Re: [OpenLayers] #2935: measure control should be able to calculate immediately while mouse is moving
OpenLayers trac-20090302 at openlayers.org
Fri Nov 19 04:06:58 EST 2010
moving
 Reporter:  patzi            |       Owner:  tschaub
     Type:  feature          |      Status:  new
 Priority:  minor            |   Milestone:  2.11 Release
Component:  Control.Measure  |     Version:  2.10
 Keywords:                   |       State:
Comment(by patzi):
 Replying to [comment:2 ahocevar]:
 > I am not sure if we really need a new event here. With a new option
 (called "aggressive" or something), the measurePartial method could also
 be assigned to the handler as modify callback.
 That's true and sounds even better as it is still a partial measurement.
 But you can't use the measurePartial method cause you get a point and a
 feature from the callback and not point and geometry. I have a new patch
 attached that will not have a new event but will fire the "measurepartial"
 event instead.
Ticket URL: <http://trac.openlayers.org/ticket/2935#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
