[OpenLayers-Trac] Re: [OpenLayers] #2941: OpenLayers.Control.Navigation with documentDrag enabled removes all document events.
OpenLayers trac-20090302 at openlayers.org
Sun Nov 21 05:52:03 EST 2010
document events.
 Reporter:  mgleahy       |       Owner:
     Type:  bug           |      Status:  new
 Priority:  minor         |   Milestone:  2.11 Release
Component:  Handler.Drag  |     Version:  2.10
 Keywords:                |       State:  Review
Changes (by ahocevar):
  * state:  => Review
Comment:
 This seems to be a regression caused by r10873.
 I am attaching a patch that uses Event.observe/stopObserving. As mgleahy
 stated correctly, this is not as straightforward as it may seem, but it
 pays off: creating and destroying Events instances is relatively expensive
 compared to just observing events. My patch also moves the code for adding
 the observers to a separate addDocumentEvents method.
 The document-drag.html example still works as expected, and tests still
 pass. Thanks for any review.
Ticket URL: <http://trac.openlayers.org/ticket/2941#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
