[OpenLayers-Trac] [OpenLayers] #2946: Panel: New icons and new displayClass for use with panels.
OpenLayers trac-20090302 at openlayers.org
Tue Nov 23 13:01:59 EST 2010
 Reporter:  jorix          |       Owner:  jorix
     Type:  feature        |      Status:  new
 Priority:  minor          |   Milestone:  2.11 Release
Component:  Control.Panel  |     Version:  2.10
 Keywords:                 |       State:
 There are some problems with icons in "theme/default/img": icons using
 "NavToolbar" have a different appearance from other icons, and the corners
 of most icons have no transparent corners.
 In patch proposes "panel_icons.gif" with transparent corners and following
 the design of "editing_tool_bar.png" but with more icons.
 Changes in "style.css":
  * New displayClass "olPanelControl" to customize panels with new icons.
 This displayClass allows: group icons, change layout (right to left, left
 to right and vertical) and supports "NavigationHistory"
  * Use the new icons on controls "NavToolbar" and "EditingToolbar".
 The patch includes a detailed example showing the possibilities of
 displayClass "olPanelControl".
 NOTE: Examples as: snap-split.html, snapping.html, wfs-snap-split.html and
 wfs-snap-split.html can be simplified by using "olPanelControl" as
 displayClass, most of CSS code can be removed.
Ticket URL: <http://trac.openlayers.org/ticket/2946>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
