[OpenLayers-Trac] [OpenLayers] #2870: Popup.Anchored: Bad
positioning using anchor
trac-20090302 at openlayers.org
Mon Oct 11 04:23:43 EDT 2010
#2870: Popup.Anchored: Bad positioning using anchor
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Popup.Anchored | Version: 2.10
Keywords: | State: Review
When the popup is created with the argument "anchor" the positioning is
incorrect. The only position that works correctly is the "br" (bottom
right), for the rest ("tr", "tl" and "bl") reserve twice the size of the
anchor. This goes wrong for "Anchored", "AnchoredBubble", "Framed" and
"FramedCloud"
Is easy to see by example "popupMatrix.html", try to move the icons at the
bottom of the map and press it: reserves twice the size of the icon.
This is a regression introduced by r10700 (in #2651) Removing r10700 the
positioning works correctly (I could not reproduce the problem described
in #2651)
No patch. r10700 is proposed to remove.
Ticket URL: <http://trac.openlayers.org/ticket/2870>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
