[OpenLayers-Trac] [OpenLayers] #2876: VML rendering issue with
polygons with zero area interior rings
trac-20090302 at openlayers.org
Tue Oct 12 18:13:40 EDT 2010
#2876: VML rendering issue with polygons with zero area interior rings
Reporter: tschaub | Owner: ahocevar
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Renderer.VML | Version: 2.10
Keywords: | State:
In IE, if you draw a polygon that has an interior ring with zero area
(what you first get while digitizing an interior ring), an unwanted
triangle is rendered between the first two points of the exterior ring and
the closing point (perhaps) of the interior ring.
To reproduce:
1. Open the [http://openlayers.org/dev/examples/vector-formats.html
vector formats] example in IE.
1. Paste in the GeoJSON below:
"type": "Feature",
"id": "OpenLayers.Feature.Vector_194",
"properties": {},
"geometry": {
"type":"Polygon",
"coordinates": [[
[-104.7, 30.1], [-104.7, -46.0], [99.8, -47.5], [98.4, 31.9],
[-104.7, 30.1]
[75.2, 3.5], [-82.2, 0.7], [-82.2, 0.7], [75.2, 3.5]
"crs": {
"type": "OGC",
"properties": {
"urn": "urn:ogc:def:crs:OGC:1.3:CRS84"
1. Hover over the feature to see the unwanted triangle.
The problem does not exist in all cases with zero area interior triangles
(tweaking the numbers above to produce a regular rectangle and an interior
ring parallel to the top/bottom demonstrates a case where the unwanted
triangle does not appear).
Ticket URL: <http://trac.openlayers.org/ticket/2876>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
