[OpenLayers-Trac] [OpenLayers] #2879: Control.Selectfeature:
clickout doesn't get triggered after map pan
trac-20090302 at openlayers.org
Wed Oct 13 09:46:14 EDT 2010
#2879: Control.Selectfeature: clickout doesn't get triggered after map pan
Reporter: jschumann | Owner: elemoine
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Control.SelectFeature | Version: 2.10
Keywords: clickout, handler,pan | State:
When having a SelectFeatureControl on the map with clickout:true; it does
not trigger the clickoutFeature() after the map panned via mouse drag.
Reproduce on http://openlayers.org/dev/examples/select-feature.html:
- draw point
- click "select feature" and check "click out to unselect features"
- click on the point -> gets highlighted
- click anywhere on the map -> point gets unhighlighted -> correct
- highlight point again, then click "navigate" and drag the map
- click "select feature again" (point is still highlighted)
- click anywhere on the map -> point does not get unhighlighted -> wrong!
- only clicking the point again to unhighlight makes it work again
Editing OpenLayers/Handler/Feature.js in the deactivate method and
commenting out the line "this.lastFeature = null;" as suggested by
elemoine on the mailinglist does help but maybe breaks other things.
Ticket URL: <http://trac.openlayers.org/ticket/2879>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
