[OpenLayers-Trac] Re: [OpenLayers] #2873: Build: Compressed code
"OpenLayers.js" can be reduced by 9k
trac-20090302 at openlayers.org
Wed Oct 13 17:52:59 EDT 2010
#2873: Build: Compressed code "OpenLayers.js" can be reduced by 9k
Reporter: jorix | Owner: jorix
Type: feature | Status: reopened
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Resolution: | Keywords:
State: Review |
Comment(by jorix):
Replying to [comment:15 erilem]:
> And thanks a lot jorix for bringing up the issue.
Thanks, I'm surprised to see much movement in one of my tickets, I am glad
it is useful.
Precautions to consider:
The '''cache''' introduced in #2389 for "_getScriptLocation" '''has been
lost'''. It is used in Map.js and in "Util.getImagesLocation"
My first solution was to copy _getScriptLocation in singleFile.js, once
prepared, I dismissed it because I thought it would be rejected, ups!
:-)[[BR]]
I worked with some premises that can serve:
* Put bold comments in both files warning to future developers of
duplicity (missing).
* Can copy and paste the code of _getScriptLocation function to
singleFile.js if changes are made (now are different)
* Ensure compatibility with old *.cfg which does not exclude
OpenLayers.js (guaranteed)
* Put the same "@requires" in the two files (in "singleFile.js" missing)
What to do with "VERSION_NUMBER"? Now I've done an SVN Update in my local
copy and and "OpenLayers.js" says 10822 and "SingleFile.js" says 10823!
Ticket URL: <http://trac.openlayers.org/ticket/2873#comment:22>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
