[OpenLayers-Trac] Re: [OpenLayers] #2884: Wrong VML rendering
OpenLayers trac-20090302 at openlayers.org
Tue Oct 19 02:49:08 EDT 2010
  Reporter:  ondrejl                 |       Owner:  ahocevar
      Type:  bug                     |      Status:  reopened
  Priority:  major                   |   Milestone:  2.10 Release
 Component:  Renderer.VML            |     Version:  2.10
Resolution:                          |    Keywords:
     State:  Awaiting User Feedback  |
Comment(by ondrejl):
 - I tried to turn on anti-aliasing (Mapserver 5.6.5 with AGG) on private
 server but problem is still there
 - I tried to copy your OpenLayers homepage with xhtml doctype and replace
 map settings with my layers but no effect.
 - finally I test combinations different versions OpenLayers with including
 VML.js
 You can see it on images in test_03.zip. Please can you describe me what
 exactly should I change in a source code to fix bug? Thanks
Ticket URL: <http://trac.openlayers.org/ticket/2884#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
