[OpenLayers-Trac] Re: [OpenLayers] #2899: Remove overhead from
OpenLayers.Class
trac-20090302 at openlayers.org
Fri Oct 22 16:56:36 EDT 2010
#2899: Remove overhead from OpenLayers.Class
Reporter: ahocevar | Owner: tschaub
Type: feature | Status: closed
Priority: minor | Milestone: 2.11 Release
Component: BaseTypes.Class | Version: 2.10
Resolution: fixed | Keywords:
State: Complete |
Comment(by erilem):
> @erilem: I ran the benchmark you created for (a) on my machine, and
after several reloads I have to say that sometimes pure js, and sometimes
OpenLayers.Class wins. The benchmark you created for (b) is unfair,
because we do not have 10000 base classes in the library, only (educated
guess) about 20. And to compare OpenLayers.Class and pure js for classes
that inherit from other classes, you would also have to call
OpenLayers.inherit in case 2 of (b). But again, I'm not against removing
OpenLayers.Class in 3.0. Thanks for the cooperation on this! We just made
class instantiation 10 times faster.
You're right that my bench isn't representative of what we have in the
lib, but the thing is: defining a type with {{{OpenLayers.Class}}} is ~13x
slower than defining it with plain !JavaScript. I'll try to come up with
realistic benchmarks. I'd like to be sure that it's worth editing 250+
files :-)
Ticket URL: <http://trac.openlayers.org/ticket/2899#comment:15>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
