[OpenLayers-Trac] [OpenLayers] #2900: Add Google's closure compiler
to build tools
trac-20090302 at openlayers.org
Sun Oct 24 06:29:10 EDT 2010
#2900: Add Google's closure compiler to build tools
Reporter: pwr | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: build | State: Review
For those who don't know it, closure compiler
http://code.google.com/closure/compiler/ compresses JS files with 3 levels
of compression:
- WHITESPACE_ONLY - similar to current minimize
- SIMPLE_OPTIMIZATIONS - which shortens local variables, e.g. 'var
meaningfulName' becomes 'var a'
- ADVANCED_OPTIMIZATIONS - which does some more 'aggressive' compression
to reduce the file-size further
http://code.google.com/closure/compiler/docs/api-tutorial3.html
I've been trying SIMPLE_OPTIMIZATIONS for a couple of months now, and find
that it reduces build-file size by some 20% over the current minimized
version without any loss of functionality - at least that I've noticed :-)
I ran through the whole test suite using this optimized version and it
produced identical results to the standard build.
The compiler is a java program which can be downloaded and run locally,
but it's also available as an online web service which can be accessed
with, for example, a python script. I attach Google's sample from
http://code.google.com/closure/compiler/docs/api-tutorial2.html modified
to use SIMPLE_OPTIMIZATIONS. This can be run with something like:
./closurecompile.py <url of file to compress> > compiledBuild.js
or you can post the actual code to be compressed.
I would suggest that other people try out SIMPLE_OPTIMIZATIONS to check
the functionality is unaffected, and once confirmed that this be used for
the public api file.
Whilst I would expect there to be no impact on SIMPLE_OPTIMIZATIONS, I
would be less confident about ADVANCED_OPTIMIZATIONS, though it might be
worth designing v3 with this in mind, as it would probably reduce file-
sizes further.
Ticket URL: <http://trac.openlayers.org/ticket/2900>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
