[OpenLayers-Trac] Re: [OpenLayers] #2697: Handler.Box: destroy drag
handler
trac-20090302 at openlayers.org
Thu Oct 28 15:39:14 EDT 2010
#2697: Handler.Box: destroy drag handler
Reporter: fredj | Owner:
Type: bug | Status: reopened
Priority: trivial | Milestone: 2.10 Release
Component: Handler.Box | Version: SVN
Resolution: | Keywords:
State: Needs More Work |
Changes (by jcachat):
* status: closed => reopened
* state: Complete => Needs More Work
* resolution: fixed =>
Comment:
There is a problem with this patch. dragHandler is destroyed and nulled
out before calling the base destroy method. If you step through
OpenLayers.Handler.prototype.destroy it will eventually call back into
Box.deactivate() if the handler was active at the time it was being
destroyed. This causes a null exception in Box.deactivate() when it tries
to call this.dragHandler.deactivate().
The solution I found was to change Box.destroy() to first call
OpenLayers.Handler.prototype.destroy then take care of destroying the
dragHandler.
Ticket URL: <http://trac.openlayers.org/ticket/2697#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
