[OpenLayers-Trac] Re: [OpenLayers] #2818: add
OpenLayers.Filter.Callback
trac-20090302 at openlayers.org
Mon Sep 13 10:29:53 EDT 2010
#2818: add OpenLayers.Filter.Callback
Reporter: alexdean | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Filter | Version: 2.10 RC1
Keywords: | State: Review
Changes (by alexdean):
* state: Awaiting User Feedback => Review
Comment:
Interesting. I didn't consider overloading `evaluate` in that way.
This would allow assertions based on a feature's attributes, but still
would not allow assertions based on non-attribute data, like geometry
type. OpenLayers.Rule will only supply the full feature to `evaluate`
when using OpenLayers.Filter.FeatureId.
The sample code you sent would have to be re-written like:
new OpenLayers.Filter({
evaluate: function(feature) {
return( feature.density >= 100 || feature.population >= 200000 )
Granted, that's a minor change for this specific example. But if I wanted
to only apply my styling to points, I would still be unable to do that due
to how OpenLayers.Rule is written.
source:trunk/openlayers/lib/OpenLayers/Rule.js at 10706#L173
I'm unable to write things like
return( feature.geometry.CLASS_NAME == 'OpenLayers.Geometry.Point' )
Would you consider a patch to change all Filter subclasses to expect the
full feature as an argument, so they'd all be treated like
`OpenLayers.Filter.FeatureId`? I believe that would not be very complex
to do, would remove the special case code for
`OpenLayers.Filter.FeatureId`, and would allow filters based on non-
attribute data in the way you suggest above.
Ticket URL: <http://trac.openlayers.org/ticket/2818#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
